Author Topic: 2 questions on mismatched voltages.  (Read 1553 times)
ChrisFL8
« on: February 23, 2007, 10:46:06 AM »
#1:
I have a 12v inverter with an 110-120v AC output. However, I live in a country where the power source is 220-240AC. What would I need to do to run 220-240v appliances?
#2:
Is it possible to connect a 24v battery to a 12v inverter?
Your 2 rather unresearched questions  were combined for brevity.
« Last Edit: February 23, 2007, 10:46:06 AM by (unknown) »
sdscott
Re: 2 questions on mismatched voltages.
« Reply #1 on: February 23, 2007, 06:04:15 AM »
You will need a 24vDC to 220-240AC.
« Last Edit: February 23, 2007, 06:04:15 AM by sdscott »
sk windpirate
« Reply #2 on: February 23, 2007, 06:33:00 PM »
Question #1
What you have, Is what you got. (12 volts DC in, 120 VAC out) Nothing will change that.
Question # 2
12 Vot DC in Only! any more than 12 volts in, will cause smoke to come out. no more inverter. Then you buy a (24 volt 220).
« Last Edit: February 23, 2007, 06:33:00 PM by sk windpirate »
Nando
« Reply #3 on: March 01, 2007, 11:01:12 AM »
If the request does not try to hide the country of residence, many times, suggestions may appear that may help much better
The 12 DC volts/120 volts AC inverter can be used in a 220 volts AC area if you place a transformer 1:2 ratio to bring the voltage to 220 volts.
An auto transformer with the same watts that the inverter is capable, THOUGH it may be more economical to buy a 12 DC Volts/220 Volts AC out with the same operating frequency of the GRID.
You can not connect a 12 Vdc inverter to a 24 volts battery bank, the design does not allowed it, the system will blow out and "smoke and fire" damaging the inverter.
Nando
« Last Edit: March 01, 2007, 11:01:12 AM by Nando »
