Author Topic: question before buying magnet wire  (Read 1011 times)
windwatcher
« on: September 18, 2007, 01:15:21 PM »
hi folks,
    i got a 15 amp furling point on my turbine with 2 in hand awg 18 44 turns.(thanks flux) question is would i have a higher amp rating if i used awg 15 single strand 44 turns.
    reading alot learning a lot.
thanks windwatcher
« Last Edit: September 18, 2007, 01:15:21 PM by (unknown) »
Re: question before buying magnet wire
« Reply #1 on: September 18, 2007, 07:33:36 AM »
single #15 is the same cross sectional area as 2 in hand #18.
In terms of output there should be no difference. Probably in real life the single #15 will take up more winding space and the thicker lead out wire will also waste more space so you probably loose by using the single #15.
« Last Edit: September 18, 2007, 07:33:36 AM by Flux »
windwatcher
« Reply #2 on: September 18, 2007, 07:38:40 AM »
thanks again flux,glad i asked
windwather
« Last Edit: September 18, 2007, 07:38:40 AM by windwatcher »
