Hi all!
My first genny is almost ready. The blades are only thing to do now.
My question is about sizing them for best performance for my generator?
First of all i think you guys need some informations:
Dual rotor (75mm) 12 magnets each. Magnet size 12mm x 3mm.
9 coils 3 phase star wounded stator.
Each coil has 97 strands of AWG#26 wire.
A single coil is .8 ohms so each phase is 2.4 ohms.
I've done a testdrive with my friends lathe.
Open voltage results after rectifiers:
- rpm 6.9 volts
- rpm 9.8 volts
- rpm 12.8 volts
- rpm 16.6 volts
- rpm 20.0 volts
- rpm 25.2 volts
And hooked to a 12v battery amps are:
- rpm 2mA
- rpm 400mA
- rpm 1.7A
- rpm 2.2A
I think after what i've heard and read so far i'm going to make the blades
out of wood. Everybody seems to say they would perform the best.
If i have got it right the bigger the prop the higher the output in watts
but it's also much slower than a smaller prop?
I don't mind if the startup speed would be a little greater lets say like 12mph.
If there is someone with great experience with this i would be grateful for
any help.
I hope i gave you enough information for this one.
