Author Topic: Basics: concrete 101  (Read 984 times)
imsmooth
« on: June 23, 2008, 12:08:51 PM »
For my anchor points I was going to dig a 4-5' hole 2' in diameter (roughly).  I was going to place an anchor with an eye at the top and something like a scrap rotor at the bottom (welded or attached in some way).  I don't want to mix hundreds of bags of concrete.  Is it acceptable to just pour concrete to make a 2' layer at the bottom and then pour the earth back on top (another 2-3' vertical feet); or, do I need to fill the entire hole with concrete?  My tower will be between 35 and 40 feet tall with an 8.5' rotor.  Maximum winds in my area potentially are 80mph.  I'm figuring that the anchors don't need to hold more than 1000lbs maximum.
« Last Edit: June 23, 2008, 12:08:51 PM by (unknown) »
wpowokal
Re: Basics: concrete 101
« Reply #1 on: June 23, 2008, 06:36:14 AM »
What type of soil do you have?
« Last Edit: June 23, 2008, 06:36:14 AM by wpowokal »
luv2weld
« Reply #2 on: June 23, 2008, 07:23:04 AM »
The first thing to consider is just what wpowokal said. Soil
composition. If it's swamp or loose sand, I'd much rather have
something the size of an Army tank at the bottom of the hole
than just an 8 or 12 inch rotor.
If you have access to a metal recycler (scrap metal yard), maybe
you can get pieces of old railroad track, or an old mobile home
frame, or truck frame. I think one of the Dan's even used a whole
engine as an anchor base. For a deadman, think weight and/or area.
If you take a piece of 1 inch pipe and weld it
in the center of a 3 or 4 foot piece of I beam (Put an eye on the other
end of the pipe for the guy wires), then bury that 3 or 4 feet down,
it will take quite a bit of force to pull that out of the ground.
We are still assuming you're not in the swamp or loose sand.
Then, if you have large rocks available, pile them on top of the
deadman and then your concrete. The concrete will make the rocks
into one huge rock. Then the rest of your backfill.  No more than
4-6 inches of fill at a time. Then tamp (compact) the back fill.
Then another 4-6 inches, then tamp. Also you cannot tamp dry dirt.
You cannot tamp mud either. It must be moist in order to compact.
It's just moist enough if you can squeeze it into a ball with your
hand (doesn't fall apart or squirt out through your fingers).
Ralph
« Last Edit: June 23, 2008, 07:23:04 AM by luv2weld »
imsmooth
« Reply #3 on: June 23, 2008, 08:20:18 AM »
After a 1/2 foot of dirt I have a heavy clay layer, followed by clay/sand.  The clay has a reddish/orange color and is hard to dig out.
« Last Edit: June 23, 2008, 08:20:18 AM by imsmooth »
scorman
« Reply #4 on: June 23, 2008, 09:19:57 AM »
I have done exactly what you describe
photos here:
http://s145.photobucket.com/albums/r203/scorman1/Foldover%20tower/Tiltover%20implementation/
(click to enlarge photos, click again to make larger)
My total concrete was 1 yd sand, 1 yard gravel, 4 bags Portland = $50
backfill hunks of rock into wet cement
backfill with earth after set
I got fancy and cast a neat "cap" at soil level from old 5gal plastic bucket
few items ..
1" pipe with welded flange w/ 1/2" holes makes sold guy anchor
you can't weld brake rotors, weld/bolt crosspiece underneath
don't dig round hole straight down ...a slot sloping toward tower with 12inch small backhoe works
I poured one mixer load into bottom after setting anchor at 60 degrees towards tower
guys need to be out from base 1/2 distance of attachment height at top
My tower base was more complex ...that is a 4x4x4 ft hole, but used same 1" sched 80 scrap pipe, angle iron frame, (8) 5/8" bolts
BTW, great source for guy hardware:
http://www.baronsnaps.com/products_items.aspx?Category=Turnbuckles&Subcategory=Jaw+%26+Jaw&P
age=1
« Last Edit: June 23, 2008, 09:19:57 AM by scorman »
