Wind is highly variable and inconsistent. I would suggest using a battery that is charged by a wind-gen. (or perhaps a Harbor-Freight solar panel?)
Is you concern a power outage cutting power long enough for your fish to die? if so, a simple switching circuit could engage the battery when the power goes out. This would eliminate constant cycling so the battery would last longer, and also reduce the size/cost of the wind-gen/solar panel.
If you just use a utility grid-charged battery and auto-switch, its my understanding its called an Uninterrupted Power Supply (UPS).
