Author Topic: VAWT design  (Read 2071 times)
TheEquineFencer
VAWT design
« on: January 31, 2009, 04:45:59 PM »
Here's my game plan. I have two sections of 8 inch stove pipe. I plan to have 1/4 of the pipe turned to form the cup and then clamp the other 3/4 to a section of 1/8 x 1 angle iron to hold it straight. This will form the pipe into a "J" shape. I'm going to make two of them and have them facing each other. Question is what spacing do I need to have using these materials and what diameter circle for the top and bottom. Or a link with the ratios for sizing would be helpful. I know there are better designs but I'm doing this with the materials at hand. I have a quill shaft from a riding mower deck I plan to use on the base for the VAWT to turn on. This will give me a place to later attach a generator. Next question is what size/watt generator will this design be able to run? I want a simple and easy generator design. If it made 100w 12VDC I'd be happy. This is my first attempt at a power producing mill and I like the VAWT for it's looks. I have a VAWT sitting in the front yard I built a long time ago out of a 55 gallon barrel to just watch spin and it's stayed togather through 2 hurricanes. It's not secured down by anything other than the weight of itself. Later I may build a HAWT as my skills improve. I'm open for suggestions. TheEquineFencer at AOL.com.
« Last Edit: January 31, 2009, 04:45:59 PM by (unknown) »
Re: VAWT design
« Reply #1 on: January 31, 2009, 01:39:13 PM »
Hi Fencer
 I would do it the other way around if i were you.Build the hawt first since all the directions are here.
 I think the one you built years ago out of barrels will outperform this one.You seem to be describing a Rahai type blade.Johnj may chime in.
 Just my opinion and wish you the best.
« Last Edit: January 31, 2009, 01:39:13 PM by vawtman »
Re: VAWT design
« Reply #2 on: February 02, 2009, 07:20:34 AM »
J shape?...isn't that what the Lenz 2 is?
http://www.windstuffnow.com/main/L2_flying.JPG
Maybe the round part 1/2 of 8 inch stovepipe
4ft. height and the flat part 1/4 inch marine
plywood ?.....3 blades about 3 foot diameter ?
   Make a study of his design...I'm pretty sure
it's pretty close to what you have in mind maybe
produce even more than you're expecting....I
guess the angle of the blades is the critical
part from what I've concluded.
« Last Edit: February 02, 2009, 07:20:34 AM by Norm »
Re: VAWT design
« Reply #3 on: February 02, 2009, 07:23:41 AM »
thats 3 ft. x 4ft. swept area.....
« Last Edit: February 02, 2009, 07:23:41 AM by Norm »
TheEquineFencer
Re: VAWT design
« Reply #4 on: February 05, 2009, 08:22:04 AM »
The stove pipe I have is 8 inch OD and 5 foot long.
« Last Edit: February 05, 2009, 08:22:04 AM by TheEquineFencer »
TheEquineFencer
Re: VAWT design
« Reply #5 on: February 05, 2009, 08:37:27 AM »
Opps, I should have been clearer, I guess, it's not that type, it's going to be built more like two 55 gallon barrels facing each other, but will have the ends straight instead of curved.
                                             X
         XXXXXXXXXXXXXXX           X
        X                                   X
       X          XXXXXXXXXXXXXXX
        X
« Last Edit: February 05, 2009, 08:37:27 AM by TheEquineFencer »
spinningmagnets
Re: VAWT design
« Reply #6 on: February 05, 2009, 06:37:20 PM »
I "think" this configuration is called a Benesh. Using that as a search term, you might be able to find and make use of previous research.
Either way, if you make two of them on the same pole with one clocked 90-degrees from the other it will smooth out some of the pulsations.
PS I have not made one yet, just read about them. Best of luck.
« Last Edit: February 05, 2009, 06:37:20 PM by spinningmagnets »
