Author Topic: help with some motors [CLOSED]  (Read 846 times)
wingman1776
« on: March 05, 2009, 04:31:15 PM »
I am new here so i put this on newbies hope it is the right place. I have been looking a 3 phase brushless servo motors google search the board and still have a question or two I have 3 motors I am looking at.
1  http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260326924588&fromMakeTrack=true&ssPag
eName=VIP:Watchlink:middle:us
this to me looks like a good motor kind of expense but good. Only thing about this one is you look down at the motor specs and it gives two amp reading a 5 amp continous and 65 amp max cut in for 12 volt should be about 150 or so rpm ? but the amps I am not sure about. I think this motor would put out 3 phase ac and I would have to 3 phase to dc retcifer. No gearing a 7 or 8 foot blade ?
2  http://cgi.ebay.com/3KW-Brushless-AC-Servo-Motor-CNC-New-In-Box_W0QQitemZ220369677962QQihZ012QQcateg
oryZ78197QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
this motor looks good to cut in about 125 rpm good amps no gearing about 6 to 7 foot blade ?
3  http://cgi.ebay.com/CNC-Mill-Router-NEMA-34-Stepper-Motor-60kg-shaft-1-2_W0QQitemZ220363371071QQihZ0
12QQcategoryZ78197QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
This motor I am not so sure about I included it cause i have a question about the amps on it too. It sayes 6 amps pr phase and 8 leads. Look farther down it showes 8 lead hookup. I asume each one of the legs is hooked to a coil and each leg would go to a bridge retciver. You have 4 coils so you would have 24 amps max output at 2000 rpm ? voltage for this motor is not listed
It is not productive for anyone to post a bunch of dead in two weeks Ebay links and ask if they will do "X". How to select motors has been covered in detail many many times. [CLOSED]
« Last Edit: March 05, 2009, 04:31:15 PM by (unknown) »
Re: help with some motors
« Reply #1 on: March 05, 2009, 11:14:58 AM »
Posting a bunch of Ebay links that will expire is not going to help others, or you.
Read this:
http://www.fieldlines.com/comments/2009/2/26/15750/7221/7#7
Then respond there if you cannot figure it out.
A search would have found the info but I guess its easier to just ask.
« Last Edit: March 05, 2009, 11:14:58 AM by TomW »
