Being a newbie I will be kind to you but it may have been better to do more studying and ask more questions before buying magnets. Don't buy any wire at this stage.
"100RPM will produce 600watts, 600Watts means 600Watts/hr is it? "
This will need a big turbine and your little magnets won't go far towards it. Yo mention no blade diameter or likely wind speed, both will have to be larger than you think . It will get you 600Watt hrs if you can keep it producing the 600W for an hour.
"is there a way i can produce it as AC instead of DC output and connect it tomy home without any Inverting device?,"
In theory yes but you won't manage it. You will never have enough consistent wind and you will never control the thing with your ability. In reality you will not power a home directly with wind power without some intermediate storage means. That means batteries or using the grid as storage with a grid tie inverter.
"15 coils and 20 magnets will this be sufficient coils? "
Sufficient for what, what is the price of cheese?
"What could be the Gap between Stator and Rotor? "
Could be anything depending on the answers to all the other questions. Normally you make it as small as you can consistent with mechanical requirements that they never rub one another. To go larger reduces output for a given volume of magnet.
Sorry this has answered very little but you have asked nothing much that can be answered. It may be wise to spend a little money on some basic books such as one of Hugh Piggots and get a basic idea of what is reasonably possible with small wind power.
First thing to consider is your wind potential, if you have useful wind then you need to decide how big a machine you would need to supply your needs and then you can start thinking about whether it is practical. If the wind is good and your requirements small then you may be able to do something. You may eventually find it may not even be practical or you may only be able to supply some of your load and use wind as energy saving.
