No .
What it does as a motor has no relevance to what it will do as a generator. The only thing common to both is the emf. It will have the same emf at the same speed as a motor or generator. Sadly you can't get at the emf, you can only see terminal volts.
What it does as a generator depends on the energy you feed into it from the wind. You will have to run it faster as a generator than it would run as a motor at the same load current.
As I said previously if it cuts in at 12v at a certain speed you will have to turn it 2 or 3 times as fast as that to get it charging 5A into a battery.
The wind is the only thing that determines what it does as a generator, you have to feed energy into it and what goes into your battery is what you extract from the wind less the losses in the generator. Given enough wind and a suitable prop it will produce more than it can stand and will burn out. You have to furl or do something clever to prevent that.
Typically these small motors are officially rated for a bit over 5A. With the intermittent duty of wind power you can push them a bit but I think 10A is about the limit. Life depends a great deal on how much you overload it.
They were not meant for wind generators, their original use has now gone but many have found a nice market selling them as wind generators. They work and are a good starter project if they come cheap enough. Learn and move on to better things when you have experience.
