Author Topic: extra power storage  (Read 336 times)
tesla man
extra power storage
« on: May 19, 2005, 08:32:03 AM »
Now that your wind genny is up and running, and the batteries are all charged, what do you do with ANY excess electrical power?
These articles may point you to an answer:
http://pesn.com/2005/05/16/6900096_Syngas/
AEC Completes First Live Demonstration
Hydrogen-on-demand, from water, through metallurgic process.  Expecting product shipment later in 2005.
Fairchild International Corp. Announces Discovery of Almost Unlimited Inexpensive Natural Gas Substitute
No airborne emissions from inexpensive process that creates gas from biomass, waste wood, and low-grade coal.
http://jlnlabs.online.fr/bingofuel/html/aquagen.htm
The AquaFuel® generator
How to generate gas from water for use as Fuel
http://arxiv.org/abs/physics/9805031
Physics, abstract
physics/9805031
AquaFuel: An example of the emerging new energies and the new methods for their scientific study
http://www.blazelabs.com/n-aquagen.asp
Aquafuel <sup>TM</sup> Generator
notice (buried in the details) how the addition of even a SMALL amount of
pure H2, will produce extremely low emissions, when combusting these gases..
and that ANY organic material, produces "feed-stock" for the process..
lets examine (quickly) how this works:
by passing a minimal amount of electricity (35 volts dc, at 10 amperes,
minimum) > easily within the range of a common car alternator..) between two
carbon electrodes, produces an arc (lightning) that reaches about 7000 F
degrees (even under water..) add any organic (carbon based) matter (raw
sewage, compost, etc) and the entire mixture breaks down into simple
hydrocarbons, and other  flammable gases : h2, co, etc.
whenever we burn a hydrocarbon, WITH H2, we get a chemical reaction that
removes the carbon (H2 loves to bind with carbon) we get very low co2 output
in the exhaust.. mostly water..
so we now  have a reliable, simple, efficient (we can still extract the heat
from the manufacturing process)  low pollution (as compared to modern
systems: gasoline, coal, natural gas combustion, etc) sustainable, renewable
fuel, with very little technology shift (works with current technologies :
internal combustion engines, catalytic converters, etc)
I suspect that increased high temp materials, and pressure vessels, will
only improve the efficiency, as time progresses..
by using raw sewage, we can generate the fuels, and sterilize the sewage
(9000 F degree heat) at the SAME time...
expect this technology to be adopted by third world countries, rapidly..
everybody, and their dog, will be making these in their garage workshop....
« Last Edit: May 19, 2005, 08:32:03 AM by (unknown) »
bob golding
Re: extra power storage
« Reply #1 on: May 19, 2005, 06:40:46 AM »
 the carbon rod generator sounds interesting. nothing about the rate of consumption of carbon rods. from a total energy consumed viewpoint i reckon bio diesel might still have the edge IF someone can get it to work with ethanol rather than methanol. until then we are still in hock to big oil. might be worth trying to run a tesla turbine on this gas. they are supposed to have a much higher effiecency than piston engines. just dont mention zero point energy or over unity devices.
bob golding
« Last Edit: May 19, 2005, 06:40:46 AM by bob golding »
