Author Topic: superchargers  (Read 249 times)
edy252
superchargers
« on: December 10, 2004, 02:11:27 PM »
hi all..
i know that this might be a little off-topic, but it does concern the concept of energy conservation....
i've been reading about superchargers (used in cars to give some additional power)....these are simply air compressors that are turned by the car's motor (by a belt) to compress air going into the cylinders, and thus providing more O2 to be burnt with the gasoline.....but isnt this additional power provided by the motor itself? ...in other words, if the supercharger DOES provide more power, the overall process has an efficiency greater than one!
plz correct me where im wrong....
thx in advance
« Last Edit: December 10, 2004, 02:11:27 PM by (unknown) »
wdyasq
Totals
« Reply #1 on: December 10, 2004, 07:52:11 AM »
The power comes from the fuel, not the engine.  Loss of portions of this power come from conversion to heat and friction.  The stupidcharger adds heat and the improtant O2 so more fuel can be burnt... creating more heat, causing more friction, and the result is less power per unit of fuel.
« Last Edit: December 10, 2004, 07:52:11 AM by wdyasq »
Snoprob
Re: superchargers
« Reply #2 on: December 10, 2004, 08:24:09 AM »
A supercharger extracts more useable energy from a smaller engine at the cost of greater fuel consumption, ie: greater power / weight ratio.
A supercharger compresses air flowing into the engine. Stuffing more air in means stuffing more fuel and only then have you boosted energy potential. If they could get away with leaning out the fuel with more air they would - but the range of fuel-air mixture porportions that will burn in useful & controlable manner are very narrow.
The higher density fuel charge is 6 + pounds per square inch over normal atmospheric pressure so 50-percent more air/fuel goes into the engine but up to 40% of that gets lost: parasitic friction load of the supercharger, exhaust valves opening before fuel/air charge completly spent, extra heat and vibration.
Turbochargers can impede gas flow at high rpms where superchargers are a constant load that can affect low rpm and allow better high rpm power, but turbochargers are thought as the more efficient method because it scavenges otherwise lost energy...
That answer your questions???
« Last Edit: December 10, 2004, 08:24:09 AM by Snoprob »
