Author Topic: Digital clocks that run from Light and Shadow  (Read 1028 times)
« on: December 02, 2004, 09:34:59 PM »
 Here is a Too Cool story about making Digital Sundials that work from Light and Shadow without Electricity, Mirrors or Moving parts.
http://www.biol.rug.nl/maes/genk/en/gk-zw08-e.htm
   )- W o o f -(
« Last Edit: December 02, 2004, 09:34:59 PM by (unknown) »
drdongle
Re: Digital clocks that run from Light and Shadow
« Reply #1 on: December 03, 2004, 05:16:09 AM »
Neat
Carpa Vigor
Dr.D
« Last Edit: December 03, 2004, 05:16:09 AM by drdongle »
JeroenH
« Reply #2 on: December 03, 2004, 06:00:21 AM »
Very nicely done.
Also take a look at the other digital designs at the bottom of the page. Some interesting stuff there as well.
« Last Edit: December 03, 2004, 06:00:21 AM by JeroenH »
« Reply #3 on: December 03, 2004, 07:38:13 PM »
If you're feeling homebrewish you can make your own
using a laser printer to print the gratings on overhead
projection foils.
You'll have to come up with the artwork yourself
(unless somebody hacks it up and posts it).
Note that it has to be designed for the refractive
index and thickness of the plate stack.
The rest of the parts are a bunch of plexiglass
(or glass) sheets, one frosted, something to
wrap around the whole unit once completed, and
a mounting bracket.
« Last Edit: December 03, 2004, 07:38:13 PM by Ungrounded Lightning Rod »
