Nice setup there, fishfarm; geez, 40 pounds of solar cells. Yeah, that must have been tedious as hell. I just put together an LED growlight - I made the LED power boosters myself, they convert 3-12VDC to 35VDC, so it runs the LED's more efficiently. And it reduces the risk of thermal runaway - if you run a LOT of LED's in parallel, and one set starts to absorb more current than another, its resistance drops. More current flows, and you get thermal runaway until the things fry themselves.
Anyway, the entire array, just a small one for now, has 148 LEDs. That felt tedious. I can only imagine how it must have been going through those hundreds upon hundreds of cells.
One big concern I have with your setup - no shielding from blunt impacts. You mentioned a hurricane going through - no water, sure that's good. But what about flying debris, or hail?
I'm working on a small prototype using aluminum backing (heatsinking), and a polycarbonate front that's UV treated. I might consider some of that vinyl stuff though as well; nothing like extra insurance against corrosion.
My big problem with my method is going to be cost. I'd love to just see a professional panel, and do a little reverse engineering.
