Fieldlines.com: The Otherpower discussion board
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Oil sucks, wind blows.
Home
Help
Search
Members
View the memberlist
Search For Members
Hall of Fame
Register
Currently debugging, strange errors may occur. Sorry for the inconvenience.
Homebrewed Electricity
Solar
What do you guys use as a back for your solar panels?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: What do you guys use as a back for your solar panels? (Read 1027 times)
terramir
Jr. Member
on:
June 26, 2004, 06:10:53 PM »
also Another question I have enough cells to build another two solar panels,
and I was wondering what you guys use for backing of your solar panels. Because I got an idea. since these cells are relativly flat and strait they all have some flaws I could use a metal block of the same size on wood and hit it a few times in order to create a indentation to sink the cells in
the thing that worries my is that wood has a tendency to warp when moisture get's to it any ideas folks?
Let me know
terramir
Last Edit: June 26, 2004, 06:10:53 PM by (unknown)
Logged
nwcpro
Newbie
Re: What do you guys use as a back for your solar
Reply #1 on:
September 01, 2004, 09:22:53 AM »
Well, I used 1/8" fiberglass sheeting over 1/4" plywood and then mounted the cells in a layer of cheap tub and tile caulk. Since I am building them as we speak, we'll see if it works, or I threw away $300 on the cells.
Last Edit: September 01, 2004, 09:22:53 AM by nwcpro
Logged
terramir
Jr. Member
Reply #2 on:
September 28, 2004, 06:11:43 PM »
well that should work I as of yet I've only used acrylic sheets myself then again the panels I have built are hanging in windows.
I don't think it will "not work"!
my question was geared more towards a professional look since I have seen panels that are professionals (in fry's) have built I just couldn't figure what the backing was. I wanted to make two panels with the good cells I have enough for two panels that looked a little more professional
that's why I was asking
Last Edit: September 28, 2004, 06:11:43 PM by terramir
Logged
Print
Pages: [
1
Go Up
« previous
next »
Solar
