Hi, I got a 5lb box of the ebay cells a while ago but am still deciding what the best way to make the panels might be. I guess most people (including me) bought the ebay cells because the cost for a complete panel can be cut down to around $1-2cdn per watt if materials can be scavenged...in canada, the absolute minimum which you could buy panels retail for is about 7$/watt for larger panels (120W) or about 12$/watt for small non-amorphous panels (15W or less). From the discussions on this board, moisture problems in the home-built panels using the ebay cells seem to be the biggest technical problem...if a panel costs 2$/watt but only lasts 4 years before being destroyed by electrolytic corrosion, then you are actually spending much more $$$ than you would on a 7$/watt panel that is guaranteed for 20-25 years. There've been lots of proposed solutions including mineral oils, inert gas, sealing them up GOOD and hope for the best, or just plain leaving them open for ventilation - each with various problems and issues. It's hard to say how serious this moisture problem is going to be because nobody's ebay panels have been through an entire year of seasons yet...
Anyways, I've never heard of a commercial panel with moisture problems....how do they deal with this problem? As far as I've read, they are constructed in very clean environments - perhaps the air is moisture-controlled in the factory during construction? I did examine one commercial panel to see what i could learn - it was constructed with a white PVC backing material and a thin glass front, framed with aluminum. The space between cells and glass was negligible...in fact it looks like the cells are touching the glass. Also, the cells themselves have just a tiny space around them...less than 1/8" between cells. It seems to me that if you reduce the volume of air inside the cell this much, there is little air to cause moisture problems. This panel did not appear to be sealed with EVA or something similar, just sturdily constructed providing no place for moist air to accumulate and cause condensation.
Someone on this board made a lot of panels out of plywood and simply put sticky transparent plastic right over the cells on top of the plywood...with no moisture problems yet, presumably because there is no space for moisture to accumulate. Maybe we should follow his lead?
