Author Topic: Solar air conditioning project and questions  (Read 5903 times)
Psycogeek
Re: Solar air conditioning project and questions
« Reply #33 on: March 24, 2005, 07:17:33 AM »
AHHH, so basically its the gas turning back into a liquid.
« Last Edit: March 24, 2005, 07:17:33 AM by Psycogeek »
Psycogeek
« Reply #34 on: March 24, 2005, 07:32:58 AM »
yes there is a hot and cold side.
its just to reach the "efficiency" level of the beast, i am going to need to pull the heat off much faster.
when i first fired it up with lotsa amps, the hot side, just transfers heat to the cold side (with the sinks), so i at LEAST had to slow it way down.
with the little tiny one on the big sink, taking the heat away, was possible even in passive.
it will take a whole lot more stuff ($$$$) to get the test of this one done now :-(
lets see copper water block, heat pipes, pump, fans  , UGGG
they say that a heat pipe can transfer heat MANY times better than copper, because of the liquid movement.
what i am using is 2 sinks that have thick copper base plates about 1/4"
and a whole lot of aluminum fins.  the peltier is just pressed between them.
i re hooked up the small one, and it works good.
« Last Edit: March 24, 2005, 07:32:58 AM by Psycogeek »
Psycogeek
« Reply #35 on: March 24, 2005, 08:44:31 AM »
looks like sombody, is working on putting a vaccume
between the two surfaces, to reduce this bad problem
http://www.coolchips.com/technology/ccalc.shtml
20 million dollers later, they may get the efficiency up a tad :-)
« Last Edit: March 24, 2005, 08:44:31 AM by Psycogeek »
Kwazai
« Reply #36 on: March 25, 2005, 05:09:11 AM »
One of my other posts is in regard to a large case fan as a genny, but what I was actually getting at with it was to run a cpu fan from natural draught convection. It is a ridiculously small air movement, but it seems like someone is always chunking old computers (free parts....). maybe a pv-cpu fan would help with the peltier (either hot or cold side..)
L8r
Mike
« Last Edit: March 25, 2005, 05:09:11 AM by Kwazai »
Psycogeek
« Reply #37 on: May 11, 2005, 06:14:04 PM »
well i have an update on this.
the 370W peltier, i finally got operational with a heatsync that is 2 FEET high :-)
and the "cold plate" which is a smaller sync, still doesnt get cold for crud.
i keep re-testing the LITTLE tiny ones, and they are very efficient.
i assume that is has more to do with the transmission of the heat, than anything.
but it could be that this 370W thing is just a piece of junk :-(
even with a 2foot heat sync, Passive is still not good enough. a slight breeze by a fan improves it instantally and proves that passive is not very efficient.
one of the small units seperated :-( the solder came undone from to much heat, right before i soldered the tip of my index finger with it (OU-$%@^*#-CH)
my Opinion at this point is that it will be efficient and more feasable with a array of SMALL units spread out.  OR something that has many junctions but VERY sparsly populated across its surface.
like if it was possible 2 junctions (total) on each Sq inch of heat sync, instead of 400 junctions in 2 square inches.
if i get more available funds, i can continue to test a small spread.
untill then that is all i found out.
anything that can use the sun to move freon would be FAR more superior.
« Last Edit: May 11, 2005, 06:14:04 PM by Psycogeek »
