Author Topic: 24 volt solar panel, 12 volt inverter/charger, batteries  (Read 1289 times)
dougo33
« on: April 03, 2006, 11:13:07 PM »
how can i take advantage of a free 185 watt, 24 volt solar panel, when my existing system is a 12 volt sytem. i have a xantrex dr series inverter/charger 12 volt, my battery bank is now 12 volt. What can i do?
« Last Edit: April 03, 2006, 11:13:07 PM by (unknown) »
scott h
Re: 24 volt solar panel,
« Reply #1 on: April 03, 2006, 05:41:21 PM »
hello what i did for my 150 watt solar panel is i bought a bz mppt controller for like 99 dollers dont remember where i think it was good for 250 watts been running for a yaer or better with no trouble it is 24 volts in and 12 out to the battery bank good luck scott h
« Last Edit: April 03, 2006, 05:41:21 PM by scott h »
jimjjnn
« Reply #2 on: April 03, 2006, 07:34:55 PM »
Some 24v panels have a jumper in the junction box thAT CAN BE MOVED FOR 12V OPS.
check and see if it can be reconfigured can
« Last Edit: April 03, 2006, 07:34:55 PM by jimjjnn »
« Reply #3 on: April 04, 2006, 07:29:46 AM »
Some others need a couple jumpers moved around.
« Last Edit: April 04, 2006, 07:29:46 AM by ghurd »
Frank06
Re: 24 volt solar panel, 12 volt inverter/charger,
« Reply #4 on: April 04, 2006, 03:13:12 PM »
Any kind of MPPT controller will do that job - reconfiguring the panel (if possible) is obviously the cheapest solution but you might get more power out of a MPPT controller.  I use an MX60 but that's overkill for a single panel.
« Last Edit: April 04, 2006, 03:13:12 PM by Frank06 »
« Reply #5 on: April 04, 2006, 03:38:23 PM »
Several options, as explained.
And then there's ofcourse the obvious one:
sell 24V panel, buy a 12V one.
Apart from these options, have you considered switching over to a 24V system? Batteries should be easy to rewire; don't know whether the inverter is easily switcheable?
In a pinch, there exist 24->12VDC converters, for trucking applications. Most are lineal regulators (i.e. you lose 50% of the power in conversion), but perhaps switchmode-types exist? That way, you could get 80-90% conversion efficiency. Might be cheaper than a MPPT, don't know much about those last.
'free 185W panel'. Wish I had your problem :)
Peter.
« Last Edit: April 04, 2006, 03:38:23 PM by dinges »
