As part of my continuing study into plans for a solar electric system for my home there are some areas where I would welcome comment and opinion. I have searched this website and can find bits and pieces on the subject, but the search engine is a bit of a pig's ear to use so I may well have missed some previous material.
Back to basics. I mentioned in a previous post that I had purchased a 2 volt 200 milliamp cell to play with. After soldering on contact leads I decided to examine the output voltage - this varied from 1.5 to 1.7+ volts despite bright sunlight. I first thought that what the cell was rated at and what one actually got in the way of volts was the way it was. It turns out not to be so. A few days later I hooked up the cell to a volt meter whilst I worked on something else. The day was blessed with strong sunshine and after an hour or so I checked the reading. The meter was showing the cell output at 2.2 volts. I was astounded and then realised that solar cells need time to warm up in order to produce full output. This is a small detail that never appears to feature in the small print.
Having regard to this information I then pondered on what was best for a solar cell panel. Do I build a panel and assume a 2 volt output and rig for, say, 7 sets of cells for a 14 volt supply, or, 8 cells for 16 volt supply, or do I assume a lesser factor of, say, 1.5 volts per cell and rig the panel for 10 cells to produce 15 volts. The logic to this is that one cannot enjoy 100% pure blue sky all the time and even in cloudy days the cells will happily produce 1.5 volts albeit they are rated at 2 volts. (Forget watts for this part of the enquiry). What are your ideas and views? I understand solar panels now in terms of series and parallel make up, but the foregoing is simply an address about final output voltage.
Back in the home I have documented the voltage and wattage of every single electrical item in the house. The question is where do I pitch my everyday `demand' figure for watts? Nobody uses every single appliance in the house at the same time. Seasonal changes determine whether an electric blanket is used for a few weeks, or whether an air conditioner is used for several months. It is possible to identify regular use items such as the electric kettle, refrigerator, television, telephone transformer, bedroom lights, hot water heater, computer and so on. Is this how everyone else works it out or does someone have access to a more scientific calculation?
At the end of the day it does not matter if the power supply is from wind, solar or hydro, we are all working at a solution that mitigates the use of a grid supply in favour of renewable sources. Please let me know how you approached the problem.
Regards,
Dave HK
