If your battery is at 11.4 volts(very low), that is what your volt meter should read. It will take hours(days probably) to bring the battery voltage up charging with a small panel. If your panel is not aimed directly at the sun, your watts will suffer, or if there is a hase, or clouds.... Just a thought. Gary D.
