The kill-a-watt meter plugs into an AC socket, and you plug your appliance (pump) into that. It will tell you Amps, Volts, Watts, Hours, and (k)Watt-Hrs.
This is great if your pump has an AC plug. If not (it's hard-wired, which is most likely), you need to cut the wires and fabricate your own socket and plug to make this possible. Do not try this if you don't know what you're doing; if you're not sure if you do or not, you don't.
If you just have a multi-meter, this won't help you much unless it's a very good one, and even so, you'll have to fabricate your own wiring to make it work. If you are serious about generating your own electricity, definitely get yourself a kill-a-watt meter; it's about $35 and worth it for the info that it will give.
Dave
