Homebrewed Electricity > Solar
HF 1.5Watt Panel Question?
coldspot:
Humm,....
" just control the LED"
Kind of what I thought
But, being that it has about twice the amount of stuff the newest, "Solar Panel Regulator Charge Controller 60W 12V 5A"
I bid on and won: "TPS-545"
But was shipped : "TW-910 "
So I thought, Humm,....
More junk!
Someday I'll buy a real controller!
asheets:
I always cut the plug off of mine, but the instructions do say that the panel will charge the battery even if the LED burns out.
Bruce S:
Umm , that is only partially true :;-)
If it burns in the shorted mode then it will charge and dis-charge as the LED will then be considered a piece of wire .
If it burns out like most diodes usually due , you will not get charging as it will be a complete open just like a fuse.
asheets:
Mine have an extra zener diode in it, which I think is to prevent that problem. Like I said, I don't care because I cut the whole thing off and use external diodes instead.
ZooT:
I cut mine off too.....Idon't need an LED or a cigarette lighter plug on them.
chuckling......I use them with either the TPS-545 or the TW-910 controllers I have sitting here to charge 10 AA cell nicad banks and then use those banks to run LED lights.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
