Author Topic: My Solar Panels 60% power increase?  (Read 1455 times)
gotwind2
  • ben[at]gotwind.org
« on: February 11, 2007, 12:16:41 PM »
I connected up my 8 year old 500mA monocrystalline panel today and out of interest took a current reading.
I have never seen more than 500mA even in sunny June from my solar panel.
Today my multimeter is reading 840 mA???
Temperature is 9 deg C. We have had a lot of snow recently, maybe this contributes to more reflected light and increased power somehow - probably wrong.
Thoughts welcomed.
Ben.
« Last Edit: February 11, 2007, 12:16:41 PM by (unknown) »
disaray1
Re: My Solar Panels 60% power increase?
« Reply #1 on: February 11, 2007, 05:29:07 AM »
Ben...that's probably about right...cooler is better. The nominal ratings apply at 25degC, and colder temps bring the current right up. It's like a bonus.
 Have fun,
 David
« Last Edit: February 11, 2007, 05:29:07 AM by disaray1 »
jimjjnn
« Reply #2 on: February 11, 2007, 09:19:18 AM »
Sun reflecting off snow and cooler panel
« Last Edit: February 11, 2007, 09:19:18 AM by jimjjnn »
« Reply #3 on: February 11, 2007, 10:40:09 AM »
Ben;
I see an increase, too but not at that level. maybe 15 to 20% but never investigated beyond noticing that rather than the 9 amps I see in summer I am getting 10+ now in full sun but we get true cold here a lot.
I just smile and burn it up ;=>
« Last Edit: February 11, 2007, 10:40:09 AM by TomW »
commanda
« Reply #4 on: February 11, 2007, 01:56:54 PM »
First, check the batteries in your multimeter, I have several meters that read high when the batteries are low.
Second, have a look at Poulek's concentrating traxle. He claims the mirrors increase output by up to 100%.
http://www.solar-trackers.com/concentrator2.htm
« Last Edit: February 11, 2007, 01:56:54 PM by commanda »
« Reply #5 on: February 12, 2007, 03:27:54 PM »
Also, in general, a cold battery in your meter will put out less power than a warmer battery.  Just like car batteries, the reaction rates  for the chemical reactions decreases for almost all common battery types.  Rich
« Last Edit: February 12, 2007, 03:27:54 PM by richhagen »
Spdlmt150
« Reply #6 on: February 16, 2007, 06:51:39 PM »
I have seen the same thing with my four pw-750 panels. Snow on the ground (reflected light) and cooler temps almost double the AH I get from the panels on a good day - I do have some shading later in the day. Now if I could see sunlight more than a couple days a month during the winter.....
I remember reading an article many years ago about an antarctic monitoring station. They mounted panels vertically. The reasoning was that the reflected light from the snow & ice boosted output, and the vertical orientation kept them from packing with snow.
« Last Edit: February 16, 2007, 06:51:39 PM by Spdlmt150 »
