a couple of questions if i might?
i am trying to make sense of your measurements
are they 8 feet in length,, i would appear so from the pics?
i assume the 39" is the width across the curve?
the reason i ask is,, if the 39 inches is the width, and if the curve is half a circle then the focal point should be approx 19.5 inches (the radius of a 39" circle)
if your radius is larger then the focal point will be correspondingly longer in length, it appears in the pictures that you focal point is far too close.
what radius is your setup based on, and what is your focal distance,, the pictures might distort the actual dimensions, i dunno.. but would like to know.
what is your focal length and mirror radius?
looks like neat project
bob g
