yes, you can but you will be throwing away half of your power, because in series your panels will be limited by the ones with the lowest Isc. your 3 150 watt 12 volt panels will be limited by your 180 watt 24 volt panel. your Voc will be 108, but amps will be around 5, for 83*5= 415 watts instead of 630 watts
Vmp will be around 83 volts
150 ft run would require # 8 wire to have 2% loss
running just the 3 150 watt panels in series you would have 450 watts, voc 64.5V Isc 8.2A, Vmp around 50 volts and run #6 wire and have your 180 watt panel to use elsewhere.
Dustin
Mad River Wind and Hydro
