Author Topic: 48 volt panels?  (Read 1266 times)
Phssthpok
48 volt panels?
« on: June 15, 2008, 04:32:33 AM »
 I have two panels that I bought off Craigslist that list specs as follows:
Pmax    50W
Vmp     78V
Imp     .64A
Voc     102V
Isc     .79A
I think they're for a 48v nominal system voltage, but I've been searching all day and I just can't seem to find out what a typical Open Circuit Voltage would be on a 48 volt panel.
Does anyone here have any idea?
« Last Edit: June 15, 2008, 04:32:33 AM by (unknown) »
Re: 48 volt panels?
« Reply #1 on: June 15, 2008, 03:00:16 AM »
They'd probably do well for a 48V system with (say) an Outback MX-60 MPPT controller at a guess, but my system is all 12V and very simple (not MPPT) so I'm no expert.
Maybe without MPPT a Vmp of 55V would be a better match for PWM style charging, but the Voc is likely to be much higher anyway.
« Last Edit: June 15, 2008, 03:00:16 AM by DamonHD »
PaulJ
Re: 48 volt panels?
« Reply #2 on: June 15, 2008, 06:10:56 AM »
   Voc on a 48V panel in full sun should be around 80V.
   The panels you have are probably intended for a higher voltage grid-tie application. They'll work fine (but with slightly lower efficiency) into 48V as long as your controller can cope with the higher Voc.
   Paul.
« Last Edit: June 15, 2008, 06:10:56 AM by PaulJ »
scottsAI
Re: 48 volt panels?
« Reply #3 on: June 15, 2008, 12:24:20 PM »
Think of it this way:
12v panels have OC voltage of around 20v.
Peak power at 17v.
Therefore 12 * 4 = 48, so 78v is correct.
Have fun,
Scott.
« Last Edit: June 15, 2008, 12:24:20 PM by scottsAI »
independent
Re: 48 volt panels?
« Reply #4 on: June 15, 2008, 05:03:17 PM »
Measure them with a DMM (digital multimeter) before you do anything else.
Open circuit voltage in full sun as well as closed circuit current--for kicks, probably literally if you aren't too careful.
Afterwards, check the junction box, again with your DMM, to see how they are wired. I have heard of 24v panels wired as 12v panels, so there's a chance you may be able to use them in a more accessibly sized voltage system.
« Last Edit: June 15, 2008, 05:03:17 PM by independent »
independent
Re: 48 volt panels?
« Reply #5 on: June 15, 2008, 06:16:35 PM »
That came out wrong. I meant, I would measure it with a voltmeter before doing anything else as it sounds on the high side for a 24v setup but that sounds what they are for. hth
« Last Edit: June 15, 2008, 06:16:35 PM by independent »
