Author Topic: solar panel building  (Read 1008 times)
lookrent
« on: August 15, 2008, 12:15:09 AM »
hello folks, i have a question about solar panel construction.i purchased a lot of solar cells and i wonder what voltage to make the panels.I will include the ebay item # for the cells.what size/ voltage do you think?(315) item# 300210053881
« Last Edit: August 15, 2008, 12:15:09 AM by (unknown) »
Re: solar panel building
« Reply #1 on: August 14, 2008, 08:09:22 PM »
According to the ebay listing they are 5v and .25 watts.
If you want a 12volt system, then four in series to make 20v open circuit nominal would be suggested. You would need parallel sets on the panel to give the wattage you want.
Those are small, but efficient cells. What do you plan to power?
« Last Edit: August 14, 2008, 08:09:22 PM by dnix71 »
lookrent
« Reply #2 on: August 15, 2008, 07:33:38 AM »
I plan on using the panels to charge a battery set.I have a large inverter and the set up will be used for powering a few items during power outages.I live in upstate new york and winter power outages can be a problem.I want to build my own panels but I am not sure what physical size to cut my backing to start construction.I am using 1"square tube and aluminium sheet material with a plexy cover.
« Last Edit: August 15, 2008, 07:33:38 AM by lookrent »
farmbo
« Reply #3 on: August 15, 2008, 02:33:34 PM »
where in upstate ny??? i am just north of binghamton
« Last Edit: August 15, 2008, 02:33:34 PM by farmbo »
lookrent
« Reply #4 on: August 15, 2008, 03:19:05 PM »
north of utica.
« Last Edit: August 15, 2008, 03:19:05 PM by lookrent »
