I bet this has been thought of before, but I don't see anyone doing it, so maybe it's a dumb idea...
I want to make a single axis tracker for PV panels. My idea is this:
Set up the panles so that they move like a louvered window shade. Put a container of water on either end, say a 50 gal drum. With a small pump, move water from one to the other. As the wieght changes, the panels move to face the sun. Seems simple and not too much in the way of moving parts.
Thinking about it, I could use a conterwieght on one end, and have the two water containers at the other end. That would make only one hanging drum. Seems like it should be good in high winds too, I can just use more or less water to obtain the correct position. At the end of the day, let water siphon back to the container on the ground.
Too silly?
Jonathan
