Author Topic: duel blade wind generator  (Read 2091 times)
michael2
« on: September 09, 2006, 12:10:11 AM »
I was looking to know if anyone has ever tryed 2 blades on 1 gen? Theres one place on the net that is selling them,i was wondering how good they are?thanks for your help
« Last Edit: September 09, 2006, 12:10:11 AM by (unknown) »
Titantornado
Re: duel blade wind generator
« Reply #1 on: September 08, 2006, 06:58:50 PM »
I'm assuming you mean two prop rotors, rather than 2 blades, which can be mistaken for two bladed prop.
« Last Edit: September 08, 2006, 06:58:50 PM by Titantornado »
andyman5002
« Reply #2 on: September 09, 2006, 11:33:57 AM »
Why is this in water? I have seen them for sale on ebay uk comming from the USA, not sure if what they claim is true about their power ratings.
Andy
« Last Edit: September 09, 2006, 11:33:57 AM by andyman5002 »
jmk
« Reply #3 on: September 09, 2006, 08:39:10 PM »
 I saw a program on tv about the Challenge Wind Mill And Feed Mill Co. They were one of the first companies to build wind mills in the states. They made an impressive double header that actually has four rotors. The two main rotors were 32' in dia. They were hooked up about 12' apart. It reminded me of a farris wheel. It had the Two 10' rotors that were in between perpendicular to the big ones. They controlled the yaw of the machine. When the wind would hit the 10' rotor, ether side it would turn an axle with a worm gear that would turn the main pivot. So if  the wind changed and hit one of the smaller rotors it would turn making the whole machine turn so the larger rotors would be directly in the wind. They used it on top of a three story grain mill. The mill ran machinery on all floors. The Co was in Batavia, Ill. They ended up with about four other commercial companies in the same city. They claimed that if anyone could out power their mill they could keep it. With the same size double header machine. The down fall was the wooden blades didn't last long, and electricity was made available for the factories. This machine had more than 1,000 blades on it. They were spaced about 2-3 " apart. I wish I could find a picture of it. They actualy made 45' dia machines, but the show was on the restoration of the 32'. The large rotors spun opposite of each other. It was painted white with the outer five foot red. As far as wind turbines go I don't know.
« Last Edit: September 09, 2006, 08:39:10 PM by jmk »
michael2
Re: duel rotor wind generator
« Reply #4 on: September 10, 2006, 11:38:04 AM »
I was wondering how 2 rotors would work on 1 shaft gen?Some pm dc motors have shafts coming from both ends.You would still get the higher rpm from the smaller  rotor blades but more torque from the 2 rotors.They are sold on the net in the US for 2000 but that is a lot of money to find out if it works any better then one rotor.Maybe its one of the to good to be true deals.Has anyone ever put anything together like this?
« Last Edit: September 10, 2006, 11:38:04 AM by michael2 »
michael2
« Reply #5 on: September 10, 2006, 11:42:54 AM »
Hi jkm
i would love to see some pis of that!
« Last Edit: September 10, 2006, 11:42:54 AM by michael2 »
jmk
« Reply #6 on: September 10, 2006, 06:49:17 PM »
 I have the program taped. If I could only figure out how to get the picture from the tv to the cumputer? I'll try to take a picture of the tv.
« Last Edit: September 10, 2006, 06:49:17 PM by jmk »
jmk
« Reply #7 on: September 10, 2006, 08:11:33 PM »
« Last Edit: September 10, 2006, 08:11:33 PM by jmk »
elvin1949
« Reply #8 on: September 11, 2006, 08:22:53 AM »
Yeah buddy
 These things were the biggest and best in there day.Not many left [lots of wood].Built from the 1870's till the 1930's i believe.They were mechanical machine's.
 The large blades made the power,the small blades aimed them into the wind.
elvin
« Last Edit: September 11, 2006, 08:22:53 AM by elvin1949 »
