That particular design, the "Gorlov" with 'wings' made for air, is the only VAWT I see having promise as build able and practical. It solves a lot of problems Sandia never figured out with millions of US taxpayers monies. They are also using what appears to be proper generators.
On page 5 of their site they give power output. I used the 2kW model as a check to see if their figures may be true. The 2kW model is 3m tall and has a 3m diameter. This is equivalent to an HAWT of 3.4m in diameter. The friendly 'bot' on the IRC channel calculated a 3.4m diameter HAWT in 44km/hr (12m/s) would output 1.6kW. It would only take a bit more efficiency for the 2kW claimed to be possible.
I would sure like to see one in person to gleam ideas and take a few measurements before I undertook to build a duplicate.
