.... and I wondered what's the most total weight anyone has hung off that wheel bearing and how long has it been flying ? I keep telling myself that the rear wheel hub, tapered bearings also that is from a Caravan must have at least 400-500 lbs. on it constantly and as long as everything is balanced (no problem). It's just hard for me to see things in reverse I guess. Each blade is almost 10 lbs. The rotor & magnets must be another 10 lbs, I have wooden disks as spacers and plates for the "sandwich" mount so I'll guess another 10 lbs, say a few lbs. for bolts & nuts etc. I'm guessing total weight hanging on the bearing will be up to 60 lbs. I've replaced the bearings, races and seal and will pack it with grease after balancing so it's new. So, the big question is : how much can these bearings take ? Someone please boost my confidence a little. I know that just spinning is nothing compared to the abuse and weight on it when on the vehical, it's hard to convince myself. Thank you for any thoughts. Dave B.
