Author Topic: Air X / Air 403 stators  (Read 1485 times)
dconn
« on: July 24, 2004, 08:54:59 AM »
Hi All
Does anyone know which coil endings on a AIR 403 stator relate to which endings on a AIR X stator? both have 3 1/2 mm ring connectors but the AIR 403 has four connectors and two of these connectors have two wires while the other two have one coil ending wire each while the AIR X stator has three connectors, each with two coil end wires each. The four connectors on the AIR403 stator are colour coded: Green, Yellow, While & Black while the AIR X stator connections are numbered 1, 2 and 3.
I think that on the AIR403 stator the different winding are different sized wire but, even so, there must be a relationship between the colours and the numbers.
I think that the really important thing is the order of the phases from each other but I only have a single channel scope so I cant easily identify which phases are leading/lagging each other.
Thanks for any help.
AIR 403 Stator:
Green: 2 wires
Yellow: 2 wires
White: 1 wire
Black: 1 wire
AIR X Stator:
# 1: 2 wires
# 2: 2 wires
# 3: 2 wiers
I am interested to see if anyone knows which colours on the AIR403 wires match which numbers on the AIRX wires. I'm guessing that two coloured connectors on the 403 stator should match one numbered connector on the AIRX layout.
Thanks for any information.
Derek
« Last Edit: July 24, 2004, 08:54:59 AM by (unknown) »
Nando
Re: Air X / Air 403 stators
« Reply #1 on: July 24, 2004, 12:39:27 PM »
Send the question to the manufacturer of the units, they may answer to you.
Regards
Nando
« Last Edit: July 24, 2004, 12:39:27 PM by Nando »
RobD
« Reply #2 on: July 24, 2004, 04:41:35 PM »
Yep! Ask Jay at Southwest. He's very good and clear in his answers.
RobD
« Last Edit: July 24, 2004, 04:41:35 PM by RobD »
dconn
« Reply #3 on: July 26, 2004, 01:26:50 PM »
Thanks guys,
I have a lot of bits lying around now and I'm sure I could build another AIR unit with parts - if I ever get around to it.
Derek
« Last Edit: July 26, 2004, 01:26:50 PM by dconn »
