Depending on the area for which a turbine is designed, it will usually reach rated power between 12-15 meters per second (around 25-30 MPH)In a high wind area, the tubine will be designed for higher rated wind speed than in a low wind area. Most commercial turbines stop when wind speed exceeds 25 meters per second, so no problem with 30 mph winds.
You will have to relate the power curve of the turbine to the number of hours at each wind speed in order to determine estimated power output, as wind turbines are most efficient at extracting power when the blades tips move at the correct multiple of wind speed.
If you can, measure wind speeds at 10 meters, and at 20 meters, you can then (assuming your site is relatively flat) use the log law of wind sheer to determine how wind speed changes with height.
http://www.iesd.dmu.ac.uk/wind_energy/wetc132.html
This will tell you how rough your surface is, and allow you to estimate if there is any economic gain from raising the hub height (higher wind speed, but more expensive tower)
Also, consider if it is worth using a larger turbine, even if it means bringing in other investors, as $/kw would be lower, and generation a higher proportion of rated due to higher hub height.
