With 30 ft tsr 10, it is nearer 280 rpm than your previous 400.
At 280 rpm with a slotted laminated core you may possibly be able to get near 10kW but its a big leap from any of mine and I don't know how it will scale. I don't know what losses you can tolerate before it burns out.
For a slotted core I would go for 120 slots with 120 coils, the 30 coil arrangement would not be sensible with a slotted core.
This is also assuming you let the volts rise directly with wind speed, heating load or something. For battery charging only a few kW to load over a reasonable speed range.
Assuming about 300v at full speed I think nearer #12 0r #14 wire But I think you have a lot of tests to do before you settle that.
Fortunately I am far enough away not to worry about a 30ft rotor running at tsr 10 in a 30 mph wind.
