Author Topic: 1.5" D Stainless Steel Shaft  (Read 1006 times)
wgatenson04
« on: November 18, 2004, 09:14:13 AM »
I have just aquired a 18" 1.5"D stainless steel shaft, and I was wondering what is the max power (direct drive HWAT)wind genni that I could use that for?  Is Stainless good for genni shafts, or is some other kind of hardend steel used?  Also, does anyone know where I can find larger 3"-4" shafts, or whatever it would take for a 30KW genni?
« Last Edit: November 18, 2004, 09:14:13 AM by (unknown) »
domwild
Re: 1.5" D Stainless Steel Shaft
« Reply #1 on: November 18, 2004, 07:52:21 PM »
Although newbie i can assist. Fisher & Paykel washing machine motor used as alternator has a 1" shaft or 25.00mm and uses a stainless steel shaft. Various claims range from 350 - 1000W, where the 1000W needs 1000 RPM according to one claim. SS is a bit harder to machine but perfect for all-weather operation.
dominic
« Last Edit: November 18, 2004, 07:52:21 PM by domwild »
Inventor
« Reply #2 on: November 19, 2004, 03:51:48 PM »
The strength is determined by the type of stainless steel (304L, 416 17-4 PH etc.)
In any event a 1.5 OD shaft will be more than adequate to handle the torque,
Paul
« Last Edit: November 19, 2004, 03:51:48 PM by Inventor »
hvirtane
    • About Solar Cooking
« Reply #3 on: November 20, 2004, 04:20:53 PM »
A thumb rule among the old guys,
whom I know is that the diameter
of the wind rotor axle should
be at least 1/100 the diameter
of the wind rotor. For 1 m
rotor 1 cm axle, for 10 m
wind rotor 10 cm axle.
Stainless steel exists
in different variants.
« Last Edit: November 20, 2004, 04:20:53 PM by hvirtane »
