Author Topic: Blade tip suggestions - is there a "right" way?  (Read 1046 times)
domwild
« on: February 11, 2005, 07:03:41 AM »
I am easily confused!
General shape: Some blades have a straight edge at the tip, some tips are rounded and some have an angled tip end.
Aerodynamic profile: Suggestions are to end at the tip with a sharp edge, sharp like the trailing edge, i.e, to form the "droplet" shape into a wedge. Am I explaining myself?
Does it really make any difference?
« Last Edit: February 11, 2005, 07:03:41 AM by (unknown) »
Re: Blade tip suggestions
« Reply #1 on: February 11, 2005, 01:54:04 AM »
Unless you want to work at tsr 8 or above things are fairly forgiving.
The golden rule is to have a tapered and sharp trailing edge. A gentle radius on the leading edge is a good idea but it will still work ok if you leave it sharp.
A flat front face is easy to make and works well. Cambered blades probably are more touchy and need to be made to higher standards.  The thickest part should be about 25 to 30 % back from the leading edge.
The most important thing is for your blade to match the alternator. You can gain more from this than by any amount of fiddling about with fancy aerofoils.
The shape of the blade has a lot of influence on the matching. Using a blade with ideal twist and width at each station seems to need a lower speed alternator than a blade of fairly constant angle and width. Both will work perfectly well if you can match the load.
The old Lucas Freelite blade was constant pitch, only slightly tapered and the back surface was part of a circle, no doubt cut on a spindle moulder for simplicity.
I have tried one on a modern alternator and it works very well over the range tsr6 to tsr9.
For a commercial manufacturer making many blades for a known load condition there is no doubt a bit to be gained by carefully selecting aerofoils but for home use the simple designs are likely to be as good as any.
« Last Edit: February 11, 2005, 01:54:04 AM by Flux »
domwild
« Reply #2 on: February 11, 2005, 10:21:59 PM »
Flux,
Thanks for your advice. I may be trying to get too much out of my simple PVC pipe
blades.
« Last Edit: February 11, 2005, 10:21:59 PM by domwild »
