Author Topic: For Zigys post below.  (Read 1291 times)
« on: March 08, 2005, 04:00:01 AM »
If I do in the coment thing it allways says post failed. So I'll do it this way. Putters suck. I think why the $#%^ do you ask for a coment just to fail it? Even if I just say hi it says I used to many words?
That motor sounds like a good one for the job. Have you spun it by hand and measured the open volt yet?
4 ft blade should work well.
« Last Edit: March 08, 2005, 04:00:01 AM by (unknown) »
Re: For Zigys post below.
« Reply #1 on: March 07, 2005, 09:40:57 PM »
Hi Jerry,
It is not what you are posting, it is the title that is too long.
His title was almost too long.  When you post, it adds the "Re:" to his title, and that makes your comment title too long, so you have to take some words in the subject box out,
where it says "Re:Will this be suitable...?"
I remove everything but the "RE" when it is too long.
If you respond to this, notice where you type is called Comment.  Just above is a box called Subject:.  In the box is "Re: For Zigys post below".  This Subject is what was too long, after the Re: was added.
« Last Edit: March 07, 2005, 09:40:57 PM by ghurd »
Ziggy
« Reply #2 on: March 07, 2005, 10:48:36 PM »
Thanks for the reply Jerry. I have not recieved the motor yet, it should be here in a few days. As soon as I have it in hand i will spin it and measure the voltage and post my findings. Thanks again for the help, I am very interested in wind power and just can't wait to get a couple flying and move up to bigger and better designs. I am happy I found this board as the info here is just priceless.
« Last Edit: March 07, 2005, 10:48:36 PM by Ziggy »
drdongle
« Reply #3 on: March 08, 2005, 04:59:19 AM »
I just remove "RE" and mine went through.
« Last Edit: March 08, 2005, 04:59:19 AM by drdongle »
Hello
« Reply #4 on: March 08, 2005, 09:22:35 AM »
Sometimes it will add the 'New' subject after the username on the main / all page.
I changed the subject box to 'Hello'.  Don't know if it will show up, but 'Re:' used too I believe.  Look after 'ghurd' when you go back.
« Last Edit: March 08, 2005, 09:22:35 AM by ghurd »
Re: Hello
« Reply #5 on: March 08, 2005, 09:24:53 AM »
Dr. D,
I just noticed after your name the whole title shows up.
Strange habits these 'puters have.
« Last Edit: March 08, 2005, 09:24:53 AM by ghurd »
Re: Hello
« Reply #6 on: March 08, 2005, 09:26:37 AM »
And the second time to the main page, the 'Hello' is gone.  Very strange habits.
« Last Edit: March 08, 2005, 09:26:37 AM by ghurd »
Smithson
« Reply #7 on: March 08, 2005, 09:43:57 AM »
(blank)
« Last Edit: March 08, 2005, 09:43:57 AM by Smithson »
« Reply #8 on: March 09, 2005, 09:41:20 PM »
See, now on my puter Smithsons post above just went and completely disappeared!  Rich
« Last Edit: March 09, 2005, 09:41:20 PM by richhagen »
