Author Topic: About wood 103 and wood ax  (Read 749 times)
harrysaunders
« on: June 14, 2005, 08:51:24 PM »
HI,
   I have just got into windpower and i only wanted to charge a battery for lighting outside. I have built the wood 103's blades but i don't know if i should use the rest of the rotor from the AX as it more hardwearing or go just carry on with the 103. This is for a long term installment.
« Last Edit: June 14, 2005, 08:51:24 PM by (unknown) »
Re: About wood 103 and wood ax
« Reply #1 on: June 14, 2005, 05:56:43 PM »
The wood 103 was built at first as an alternator, after it performed well, they decided that it warranted making blades and they were put on it.  It has wooden bearings and Dan stated that he didn't think it would hold up long in high winds.  The wood AX has metal bearings, and although it is not flying, I got to take a look a the body of it when I went out there in April.  It would likely be more durable than the 103, primarily because of the bearings.  The welded ones made from pipe that they have been building out there are probably an order of magnitude more reliable.  They have a furling system to protect them from high winds, and much heavier wheel bearings.  Rich Hagen
« Last Edit: June 14, 2005, 05:56:43 PM by richhagen »
