First I'd like to say to Flux for the comments. This is kind of a follow up to a previous post.
I did some more 'surfing' and found a blade carving calculator and did some more research.
I believe there is a trade off of higher TSR vs Starting Torque (also obviously RPM). The higher the TSR the lower torque applied at given wind speed. I would assume it is the torque that is needed to 'break' free from bearing friction and get a windmill spinning at first. Not cuttin speed on the generator but to at least get it turning. Perhaps this is another topic.
Anyway I plugged numbers for a 3 meter diameter (10 foot prop) and come up with these numbers. TSR of 4 and 'attack' angle 5 degrees, 3 blade prop.
Here is what it gave me for 3 out of the 10 stations on a blade
Station 1 - 27 1/2 inches wide at the root
21 inch drop (for angle of 54 degrees)
4 1/2 inches thick.
Station 5 - 19 inches wide
4 1/4 inch drop (for angle of 13.4 degrees)
2 3/4 inches thick
Station 10 - 12 inches wide
- 7/8 inch drop (for angle of 4.5 degrees)
- 1 1/4 inches thick
The recommendations at this site are to cover 10 percent of the sweep area with blades.
Are these numbers believable and correct?
