Yaw control sure is appealing. As long as you have spare parts around, it will be pretty easy to repair.
I have used to have a machine that was made in 1945. It was a Cincinatti Hydrotel duplicating machine. Put in some oil, turn it on and it has been running for what? 60 years....
I also bought some CNC machines that were made back in the 80's. They broke down all the time and gave me fits......cost thousands of dollars to keep them going....
But have a 5 gal can of oil, and the old clunker kept right on chugging......dependable as heck.....
Consider this.
The wind does point the thing in the right direction for free and without any help.
It seems that is half of the Yaw control.
The problem is:
- : Furl control.
- : Rotor speed control.
Furling can be done with a motor, nut, and screw, a hydraulic cylinder and the mechanical ways. Pretty simple for an on/off application.
Rotor control is where it gets tricky.
I had this wild Idea. Why not just "give it something else to do"...
It occurred to me, you could bring a shaft of the opposite end of the drive axis and drive a hydraulic pump. There are several ways you could use this. You could design a hydraulic servo spool to where the faster the pump turned, the more pressure it would put on the spool and start adjusting the check valve pressure.
At the slow speeds, the bypass would flow easily across the check valve and not rob much energy. The return line would be very wide. As the RPM gets close to max, the pressure at the check valve starts to increase exponentially and you could then turn on a motor to furl it in. Or, if you used a hydraulic cylinder to furl with, it is quite possible to be able to adjust everything down to the nat.
Once it was still fully furled and still making power, the pump could start to rob the kinetic energy from the rotor. Kind of like a brake with no surface friction.
All the friction would be in the oil and easily cooled with a radiator.
More weight? I dunno, it could be very compact and not really add that much weight at all.
Anyways....just a crazy Idea.....I got to thinking about the way the Cincinatti Hydrotel was built and said hrmmmmmmmm.....
Murlin
