Several things I,ve noticed folks doing, is removeing the stators from the mold to soon, after casting and not storing them carefully.
Resins, take quite some time to fully cure -- they remain soft and are often warped from careless handling and exposure to hot sunlight, to soon after molding.
On the ones I have built, I also "pack" all available open space, between the coils, espically the bolt areas, with fibreglass filiments -- simply pull apart pieces of fibreglass matt and push it into the resin, in all available places -- you will use less resin and become much stronger, with the fibreglass strands -- the long fibres help hold everything together.
Lay your stator on flat surfaces , don,t just lay it on a pile of other objects -- cureing is a long process and that stator will be "soft" for quite some time !!
Another source for supplys is, "Aircraft spruce and specialties"in California, and they ship world wide..
Happy building, Bill H.
