Thanks very much for that Willib
in comment 33 i think it was I said this:
"Due to this torque problem I ran a single phase test only at 80hz (480rpm) and the current across the resistor gave a reading of only .594A where before with three phases, running in star, the reading was .994A roughly .6 times less current to drive the same single load. So the load in the legs of a star circuit will require some reading in my behalf."
The power curve seems too high. I'm guessing that the .6 deviation has something to do with star connections. Someone here will know how and why.... and it's not me (i thought I did, but I'm wrong)
Somehow higher current flows in the leg resistor, because it could not have reached 500W at less then 240v (lights were not fully bright), so can you do it again multiplying the current by .6. This will (I think) give a truer vale for power. How .994A can be flowing but the load only seeing .594A I don't know.
It may be a power factor thing, and the extra current is wattless current (no voltage in phase with it ) or some other explanation....
I'm not sure if that makes any sense.
And I'm after a transformer setup to relieve the stator of mismatch and heat. It also allows for the stator to be matched to the load better. Transformer losses appear to be minimul with this pole number.
Thanks for your help
.....oztules
