Author Topic: Maybe a new way to make fibreglass blade plugs?  (Read 2010 times)
gizmo
    • The Back Shed
« on: November 19, 2007, 11:53:42 AM »
Trev from Foundry & Fibreglass ( http://www.thebackshed.com/foundryandfibreglass/ )sells aluminum turbine hubs to suit the F&P smartdrives, and asked me to help him build a blade set to suit. I used the Warlock calculator to generate the figures for a 2.4 meter 3 blade turbine, and then spent a couple of hours CAD'ing it all up.
Next day I used the laser cutter to cut out 100 ribs from 12mm MDF. Each rib has a 30 by 1.2mm slot, angled correctly for each ribs distance from center.
The ribs all slide onto a stainless steel strip, and this should hold each rib at the correct angle.
Now its just up to Trev to glue it all together, apply a little filler, some sanding and he should have a very accurate blade blank. He'll use this to make a fibreglass mould.
Hopefully it will work. If it does, we'll look at making a bigger set for the dual stator F&P windmills.
More pictures and story here - http://www.thebackshed.com/Windmill/FORUM1/forum_posts.asp?TID=800&PN=1
Glenn
« Last Edit: November 19, 2007, 11:53:42 AM by (unknown) »
wdyasq
Re: Maybe a new way to make fibreglass blade plugs
« Reply #1 on: November 19, 2007, 05:47:15 AM »
Good Looking start there Glen.
Best of luck,
« Last Edit: November 19, 2007, 05:47:15 AM by wdyasq »
« Reply #2 on: November 19, 2007, 07:07:35 AM »
Glenn;
Looks like a great project.
You guys have entirely too much fun down under there.
« Last Edit: November 19, 2007, 07:07:35 AM by TomW »
Spdlmt150
« Reply #3 on: November 19, 2007, 12:48:20 PM »
Nice work. I've been wondering about alternate methods for making blades. When the time comes, please show the fiberglassing process. I would be interested in how it all turns out.
« Last Edit: November 19, 2007, 12:48:20 PM by Spdlmt150 »
« Reply #4 on: November 19, 2007, 05:39:17 PM »
Nice work there.  I am not familiar with the methods of making the plugs, but the cnc work looks nice.  I am envious of that laser there.  I would be milling or routing for hours.
When I carve my smaller blades, I calculate the profiles incrementally out,  divide the top and bottom surfaces, and adjust for the tool offsets based upon the direction of travel, a little bit different carving from one piece of wood, but your work looks familiar to me.  Rich
« Last Edit: November 19, 2007, 05:39:17 PM by richhagen »
s4w2099
« Reply #5 on: November 19, 2007, 07:41:44 PM »
Really cool, Ive always wanted to do that. The way I though about it was to do it with foam plugs. But heck, your way is cool.
« Last Edit: November 19, 2007, 07:41:44 PM by s4w2099 »
healerenergy
« Reply #6 on: November 27, 2007, 11:51:00 PM »
This is really cool work and also looks like the blades are going to be powerful. Is the CNC machine home made or a commercial one.  The work it does looks finely detailed and I'll wager the program must be pretty powerful. What kind of a laser are you using it looks huge. Of coarse when it comes to lasers I know about as much as one could put on a postage stamp in large print.
George
« Last Edit: November 27, 2007, 11:51:00 PM by healerenergy »
domwild
« Reply #7 on: November 29, 2007, 03:22:06 PM »
Wekk done! Congrats! So much fun should be made illegal.
Regards,
« Last Edit: November 29, 2007, 03:22:06 PM by domwild »
