Oil sucks, wind blows.
Frank
allan down under
I realy believe PPL supply insuficient information in ignorance of the subject most of the time, hard for me to tell the difference most of the time though.
allan
I am not sure if you are meaning blades 6ft long or 6ft diameter. 12 ft would reasonably suit your magnets, but with a 6ft prop you would haver far too much magnet for sensible use of materials. Twelve ft may be quite bold for that system of control but it might be ok.
So if I go with the 32 2" X 1/2" N50 discs for better separation of the magnets and coils, wound with two strands of #15 wire in hand x 75 turns, would that be a good fit for the blade diameter? And what cut in speed do you think I would have?
Thanks Frank
I stumbled across Ed's formula for calculating turns on coils while searching and ran my info. I'm not sure on the gauss but I think that the lower number would be a safe bet. I'm planning on using these Applied Magnet fiberglass low wind speed blades (Below) to test the unit. I'm going to make 2 hubs one for 3 and the other for 5 blades. The hubs will add about one foot to the diameter of the blades putting the turbine at 11.5' I'm looking for an early cut in without stalling the turbine. Any suggestions'?
