Thanks on the typo! 4 people editing, including 2 PhDs, and we all failed to catch it.
More below -- ADMIN
1. The book calls for 1 strand of #17 at 140 turns for the winding of the stator (48 volt). I am pretty sure we used 16 gauge wire and some other number of turns at the sustainable living fair workshop last year? I have both gauges of wire and was not sure which I should use. Have you guys found better numbers for this since publishing the book?
Nope, we haven't changed anything (if we do change ANYTHING about the 10 footer, it'll be announced in our book's blog at http://www.homebrewwind.com )-- just note the difference between the regular and heavy duty stators (and the different magnets). I can't remember, but I bet we didn't have #17 for the seminar, and used the other wire with an adjustment to the # of turns and the air gap.
2. I'm going to be starting the stator soon and had a few questions. What kind of fiberglass mat/cloth (for the stator) do you tend to order from US Composites ... there are so many different kinds? Should I just order the cheapest stuff like the 4oz E glass? Or, is there a better weave, thickness, etc?
No preference here...we often get it from the local auto parts store too.
2.1 Also, what thickness of fiberglass tape is best for connecting the copper windings (2 inch ok)?
We usually use strips of the same fiberglass mat used for the stator.
3. I am using ATH and 1/4" chopped strand for filler. What ratios of these fillers would you recommend using on the stator and magnet rotors. The book does not really say exactly, but I bet you guys have some ideas on this.
50:50 of (total) fillers to resin (page 156)
4. Were do you get the plastic / pvc sheets that you used to build the stator mold? I was thinking of building one out of plastic as opposed to baltic birch plywood because it seems that it would be much better at releasing the mold. Is that something you can find in Denver or should I order it online?
I THINK we got it at Fort Collins Plastics. Should be very easy to find in Denver.
5. Have you ever used non-wood blades. I am making one turbine for a friend in Texas and he thinks the humidity will destroy the cedar blades. What fiberglass blades would you recommend? Or, what would you do to protect the cedar blades in this type of environment?
You could try top-notch, expensive brand automotive primer and 2-part enamel on wood. Remember if you get paint cracks, the paint will do more harm than good. All the Chinese fiberglass blades we've seen have been REALLY rough and crude....sometimes amazingly bad. They also weigh 4 times what cedar blades do, so watch for bearing wear. And there are many stories about water penetration and failure of fiberglass...see "African Wind Power" (before ARE took over their blade warrenty)
Thanks for your patience -- I've been out of the office all week and hadn't checked the board until tonite (burning the midnight / weekend oil here).
DAN F
