Reg:
I'm not an expert by any little minute stretch....however as for aluminum backing ..nada.
I believe it has to do with the steel intensifying the magnetic flux...if using two mag rotors, then the steel intensifies the attraction of the flux across the air gap/stator...(an expert can correct this if need be). That is also relative to using one mag plate and steel laminations on the other side of the stator. There is also a problem with eddy currents in aluminum...what/why/how...I am not all that sure.
As for Magnets, my vote would be for the wedge type. Seems they are a natural fit for axial flow and I would think, allow the flux to cover more of the coil area. Mind you, that is on a 12-14" mag rotor plate. If one where to go with a much larger diameter mag rotor, then rectangular may do just as well.
N52 eh.? wow and I thought that N42 was about the highest...interesting and good to know.
15 to 20 Kw is gonna be a fair sized unit. I assume a grid tie/community unit.?
Just a thought, Hugh Piggots book Windpower Handbook is a pretty good investment..lots of formulae and the like..great read.. excellent info if you don't already have it.
rgds and best of luck, We all would like to see how you progress.
there will be lots of comments on your question for sure.
stk
