Hi SamoaPower.
My standard diameter for my plastic blades are 49 inches tip to tip or 24.5 inches from shaft center to tip. I call this a 49 inch blade. with the 6 inch extension the blade measures 55 inches tip to tip. I call this a 55 inch blade. With 8 inch extensions the blade mesures 30.5 inches tip to tip. I call this the 61 inch blade.
Then I just fly them in my S-10 P/U and write down the #s I see at each MPH.
I think the confusion lies in the way the blades are mounted. The 49" blade is mounted directly to the steel hub. Both the blade and the steel hub have 2' X 2" mounting tabs. In the 49" these 2 tabs are directly overlaped. Blades 2X2 directly over the hubs 2X2.
With the extensions this not the case so an additional 2" is added. Because of exact mounting locations on the extension they just camew out at 49", 55" and 61".
These are the measured diameters. Depending on where the mounting holes are drilled effects diameter.
I apolajize for the cofusion. It would have been best if I just described the blade as 49", 55" and 61" by vertue of extensions ands not used the 6" and 8" referance. Sorry bout that.
As per the amps volt #s again I just write down what the meters read and thats hard to do when your left handed, watching the road,Fluke true rms digi meter for volts, realy nice analog amp meter,truck speedo meter, the road, kids, trafic, corners and my voice recorder broke.
All of this is why I'm so desperate for to build my wind tunnel.
It will be much more accurate and safe.
