http://cgi.ebay.com/Epoxy-Casting-Resin-LowCost-LONG-POT-LIFE-192oz-SCR-BLK_W0QQitemZ270021629294QQihZ017QQcategoryZ75576QQcmdZViewItem
You Are Bidding on a 192 ounce kit of
MAX SCR
SLOW CURING RESIN
Black
- Gallon of Resin
- Half Gallon of Curing Agent
For International Orders Please Inquire For Shipping Cost
MAX SCR is a two-component epoxy based resin with a long working time specially formulated for casting large to over size items (up to 4 pounds). It is filled with thermally conductive non-metallic fillers that improves dimensional stability, reduced shrinkage and facilitates in dissipating exothermic heat. MAX SCR is easily mixed and poured into place and provides a long working time even when mixed in large volumes. A 2000 gram mass can be mixed without overheating due to exothermic heat generation and will provide up to a one hour working time. It is suitable for use with silicone, polyurethane, steel, and wood molds. MAX SCR can be demolded after 36 hours room temperature cure or for a faster demold times, post cured under heat (30 minutes at 200oF) after it has gelled for 4 hours at room temperature allow to cool and demold.
MAX SCR can also be used as a potting or encapsulating compound for elcetrical or electronic circuitry. It is very thermally conductive making it a very effective heat dissipating epoxy system.
Viscosity Part A 17,500 cPs
Viscosity Part B 250 cPs
Mix Ratio By Weight: 100 Parts A to 25 Parts B (4:1)
Mix Ratio By Volume: 100 Parts A to 50 Parts B (2:1)
Mixed Density 1.55 g/cc
Working Time: 120 minutes (400 gram mass)
Peak Exotherm: 150oF max (400 gram mass)
Shore Hardness: 75- 80 Shore D
Shrinkage: <0.20 %
Compressive Strength: 16,800 psi
Tensile Strength: 9,900 psi
Tensile Elongation: 2%
Heat Distortion Temperature: 200oF
Garry
