Trying to lift the magnet off the plate isn't going to work very often.
Free magnets are a lot of work.
Remove the whole plate it is stuck to.
Clamp the end of the plate in a vice. Slowly(!) bend the plate away from the magnet.
The glue is gummy, a quick bend will break some magnets.
Clean up all the metal sawdust around the vice before you start.
I utility knife all around through the coating, then snap with pliars. Not fun. Lose less that way.
The center 'no man's land'... mine seem like some man's land. Just not very predictable. Removeing the center 10% or whatever will keep from having part of the wrong pole in the stack.
I lost a lot of blood on the peeling coating.
Not all have 2 poles on one side. Those don't need cut. You will know when you see them.
Somewhere in the plastic near the magnet is another tiny neo. Near the back of the voice coil, maybe in a different piece of plastic. Maybe 1/8"D x 3/16L, some are square, etc.
Get some of those out too. 'fridge fun for the whole family!
And be careful. "A good sized stack of HD neos can be dangerous!" I said bleedingly.
