Author Topic: SW-403 mods underway.  (Read 751 times)
« on: December 14, 2006, 03:27:13 AM »
I hope to wind test it sunday? we'll see how it compairs to the stock version.
This is back side of blade hub
front of blade hub.
away shot
I added a larger tail. The small tail wouldn't offer much direction control.
I'll be testing this 48 volt genny at 24 volts.
« Last Edit: December 14, 2006, 03:27:13 AM by (unknown) »
Re: SW-403 mods underway.
« Reply #1 on: December 14, 2006, 05:04:00 PM »
It's alive
« Last Edit: December 14, 2006, 05:04:00 PM by tecker »
« Reply #2 on: December 15, 2006, 03:24:30 AM »
You know I 've always thought that pvc would make a good core for laminate fiberglass
I'll do a tsr one with a buildup on the root for more lift and fiberglass for stress and weather proofing .And one set with   Aluminum flashing bonded to instead of fiberglass  . That's the only issue with Pvc that the UV gets to it as a core It's head and sholders above any other core for shaping .I like this mod I know it's going to make more power.
« Last Edit: December 15, 2006, 03:24:30 AM by tecker »
swmiwindnsolar
« Reply #3 on: December 18, 2006, 12:40:11 PM »
Hello Jerry.
Yes, please keep us posted on your observations on your Jerry blades on the Air-X.
I have seen many used Air-X's for sale on E-Bay due to noise and low performance.
Perhaps these modifications will make the Air-X a viable low wattage type genny.
I have a 48 volt UPS battery bank that is on float with grid power and would love to have a decent low wattage wind turbine for battery bank float use.
Thanks, Art.
Lawrence, MI.
« Last Edit: December 18, 2006, 12:40:11 PM by swmiwindnsolar »
« Reply #4 on: December 18, 2006, 10:25:15 PM »
Hi Lawrence.
My 403 is a 48 volt unit. Because my blades are desinged for much more tourque and lower rpm I will now be useing this 48 volt genny for 24 volt charging.
Its worthless at 48 volts. However if I use it with the original blades it will act as though it is just shorted out. My blades will have enough tourque to overcome this sudo short condition.
« Last Edit: December 18, 2006, 10:25:15 PM by Jerry »
