I am trying to verifiy that the turbine in Piggot's Axial Flux Wind Turbine Plans will really produce in the ballpark of 100 W. I don't doubt that it will, but I enjoy physics and would like to work it out anyway. Here is my approach:
(1) The magnetic flux density of the magnets is known to be 12,000 gauss. With the magnetic flux density (B), I calculate the magnetic flux (P) by P = B*Area. I use the area of one coil.
(2) Knowing P, I can now calculate the flux linkages throughout the coil by multiplying P by the number of turns.
(3) The emf is equal to d( flux linkages )/dt. I assume that the magnet passes the coil in ~1/10 of a second, so I set 1/10 to dt. I set d( flux linkages ) equal to the value calculated in (2). So now, we have the voltage induced in one coil.
(4) Using the resistance/foot of 18 gauge wire, I calulate the equivilent resistance in the coil, and then with Ohm's law, the current induced.
From here on, I'm much less confident.
(5) I calculate the rms V and I values and find the rms power. I use rms values because the voltage and current are rectified. Since on the opposite side of the stator, the other coil constituting the phase is being simultaneously induced, I figured I should multiply the calculated rms power by two. (Maybe this makes no sense).
(6) Since Piggot's machine is "5 phase," this is the rms power of just one of the phases. So, to get the total rms output power at this rpm, I multiply by 5 (maybe this also makes no sense).
In summary, we went from the rms power in one coil, to the rms power of one phase (multiply by 2), to the total power output of the turbine. (multiply by 5)
If someone could affirm, set me straight, or at least point me to a helpful reference, I'd be greatly appreciative.
Sincerely,
Jack
An Aspiring Physics Student
